March 22, 2021 at 5:55 pm
Chris Kopetski
Ansys EmployeeStarting June 15, 2021, all users will be required to login to Lumerical's website using an Ansys account.
Outline
- Overview
- Can I create my Ansys account before June 15?
- Am I still using a legacy Lumerical account?
- Will my account history be lost?
- Instructions for creating an Ansys account
- Customers in China
- Need more help?
Overview
Lumerical's website login system (for access to product evaluations, downloads, support portal, KB, App Gallery, Lumerical University, etc) is switching from Lumerical accounts to the Ansys account system. This change is part of our ongoing efforts to integrate Lumerical's products and services with the rest of the Ansys organization.
You must create your own Ansys account. Your Lumerical account will NOT be automatically converted to an Ansys account.
Migration schedule:
- Oct 26, 2020: New users will be required to login with an Ansys Account. Existing users must continue to use their legacy Lumerical accounts.
- June 15, 2021: All users will be required to login with an Ansys Account.
Yes, we encourage everyone to create their Ansys Account and accept the EUC in advance, to minimize any disruption. However, you must continue to use your Lumerical username/password to access Lumerical's website until June 15.
If you registered on Lumerical's website prior to Oct 15, 2020, you are still using a Legacy account. If you can't remember when you registered, try logging into the Discovery Forum. It uses the same Ansys account system that Lumerical is moving to.
If you're still not sure, just try creating an Ansys account, as described below. It will tell you if your email address has already been used to create an Ansys account.
No. As long as you use the same email address to create your Ansys account, your account history (e.g. previous support tickets, progress within a Lumerical University course) will not be lost.
The following video shows the process of creating an Ansys Account, accepting the End-Use Certificate (EUC) and logging into lumerical.com.
Viewing 0 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
613
560
220
188
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
