Creating automatic connections for 3 D analysis of welded tubular chassis frame in static structural
June 28, 2020 at 7:25 pm
soham
SubscriberSo im creating static structural analysis of my spaceframe tubular welded chassis. i imported geometry in step format after importing i got 55 bodies in geometry to convert it into single part i merged them into single part. After that ansys asked for contact so i right clicked on the connections and clicked on create automatic connections. is it right method to proceed ? as in actual practice all those tubes will be connected by weld joint
- Limitations of ANSYS Student
- When DesignModeler is a better choice than SpaceClaim
- Off setting lines onto surfaces
- Rosette direction issue due to Geometry limits
- Free ANSYS Research software for Student Competition Teams
- Applying Moments for the Revolute Joints in Explicit Dynamics
- Meshing Problem in Explicit Dynamic-Roll Cage
- workbench
- Ansys Composite prepost analysis
- Composite Material choice in ACP
3682
2552
1751
1232
584
