June 17, 2023 at 3:21 pm
Merel Meulendijks
SubscriberI created this script below in the spaceclaim script environment. The goal is to import a .txt file, create the wanted geometry, save it and repeat this process so that 50 geometries are created and saved. However, when I run it, my previous geometry gets overwritten by the next one (in the same design file). How can I fix this? So the goal is to: create the geometry in new design, save and close the new design and open a new design to create the next geometry:
# Python Script, API Version = V23
filename = r"C:\Users\20182785\iCloudDrive\TUe\BMT\Year 3\Q4\BEP\Matlab_probeersels\1000_cosines\trimmed_cos_points_"
txtnums = map(str, range(1,51))
for i in txtnums:
DocumentInsert.Execute(filename+i+".txt", FileSettings1, GetMaps("f5a15159"))
# Set Sketch Plane
sectionPlane = Plane.PlaneXY
result = ViewHelper.SetSketchPlane(sectionPlane, Info6)
# EndBlock# Solidify Sketch
mode = InteractionMode.Solid
result = ViewHelper.SetViewMode(mode, Info5)
# EndBlock# Revolve 1 Sketch Curve
selection = Curve2
result = RevolveEdges.Execute(selection, Line.Create(Point.Create(MM(0), MM(0), MM(0)),
Direction.DirY), DEG(360), False, ExtrudeType.None)
# EndBlock
# Delete Objects
selection = CurveFolder1
result = Delete.Execute(selection)
# EndBlock
# Extrude 1 Edge
selection = Edge2
secondarySelection = Edge2
options = ExtrudeEdgeOptions()
result = ExtrudeEdges.Execute(selection, secondarySelection, MM(-20), options, Info7)
# EndBlock
# Extrude 1 Edge
selection = Edge1
secondarySelection = Edge1
result = ExtrudeEdges.Execute(selection, secondarySelection, MM(20), options, Info8)
# EndBlock
# Fill
selection = Edge3
secondarySelection = Selection.Empty()
options = FillOptions()
result = Fill.Execute(selection, secondarySelection, options, FillMode.ThreeD, Info11)
# EndBlock# Fill
selection = Edge4
result = Fill.Execute(selection, secondarySelection, options, FillMode.ThreeD, Info12)
# EndBlock# Rotate About X Handle
selection = Body1
anchorPoint = Move.GetAnchorPoint(selection)
axis = Line.Create(anchorPoint, Direction.DirX)
options = MoveOptions()
result = Move.Rotate(selection, axis, DEG(90.0000000000002), options, Info9)
# EndBlock# Create Named Selection Group
primarySelection = Face1
result = NamedSelection.Create(primarySelection, secondarySelection)
# EndBlock# Rename Named Selection
result = NamedSelection.Rename("Group1", "Inlet")
primarySelection = Face2
result = NamedSelection.Rename("Group1", "Outlet")
primarySelection = FaceRegion1
result = NamedSelection.Rename("Group1", "Wall")
primarySelection = Body2
result = NamedSelection.Rename("Group1", "Fluid_domain")
# EndBlock
filename1 = r"C:\Users\20182785\iCloudDrive\TUe\BMT\Year 3\Q4\BEP\Save_geometries\Automated\scdocs\cartery
DocumentSave.Execute(filename1+i+".scdoc") -
June 20, 2023 at 8:19 am
mjmiddle
Ansys EmployeeThere is more than one way to to go about this.
- You can use DocumentOpen.Execute() instead of DocumentInsert.Execute(), to open in a new document instead of opening into the existing document. Don’t forget to close the current document at the end of the script using Window.ActiveWindow.Close().
- You could simply delete all geometry at the beginning of the loop just before the DocumentInsert.Execute() using the ClearAll() command. This way you keep working in the same document.
Also, rather than creating a map, using “txtnums = map(str, range(1,51)),” you can loop on the integer, which is more normal, and just convert to string where that type is necessary:
DocumentSave.Execute(filename1+str(i)+”.scdoc”)
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2961
1449
1322
