Creating envelop bodies is failing in non conformal meshing
    • Xiaokang Liu
      Hi there,
      When I'm trying to model a system including PCBs and Connectors/Flex-Cable and using the Mesh Fusion function for different components, I encountered the issue "Creating envelop bodies is failing in non conformal meshing." in the initial meshing stage. Do you have a suggestion for that?Many thanks!
    • Anchal Singh
      Hello Xiaokang Liu,
      There may be several reasons for it. If you have a Service Request account then please raise an SR to address your problem in a better way.
      Regards
      Anchal
