February 7, 2021 at 11:52 am
ayodele1
SubscriberDear ANSYS,
I wish to create geometry of below isometric drawing in ANSYS SpaceClaim, for the purpose of flow simulation. Can someone please assist me with how I may approach this geometry creation?
February 8, 2021 at 5:07 amKeyur Kanade
Ansys EmployeeOnce you are done with XZ plane, you will need to rotate that plane by 90 degrees or use another surface as reference to create a plane. Then use that plane for further geometry creation. nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynFebruary 8, 2021 at 7:05 amayodele1
SubscriberHello Keyur,nThank you.nAyodele1nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5268
3299
2469
