September 20, 2018 at 9:52 am
Shajee45610
SubscriberHey!
I was wondering if it's possible to create a point mass in explicit dynamics (to shorten my simulation times)?
I created a remote point but when I click on geometry, the point mass option cannot be selected. The only option I can select is surface coating.
Any help is greatly appreciated!
Thank you
Shajee -
September 20, 2018 at 11:26 am
Sandeep Medikonda
Ansys EmployeeHi Shajee,
You should be able to insert a point mass directly by right-clicking on the geometry:
What version are you using, I just tried this in 19.2
Sandeep
September 20, 2018 at 11:30 am
Shajee45610
SubscriberHi Sandeep
I'm using 18.2, I can see the point mass option, I just can't click it for some reason. The button is suppressed. Do you think that it is a software issue?
Regards
Shajee -
September 21, 2018 at 9:21 pm
Sandeep Medikonda
I think it might have been introduced in 19. I just checked in 19.1 as well, if possible please upgrade?
Sandeep
September 21, 2018 at 9:23 pm
Shajee45610
SubscriberThanks Sandeep, will check on it.
Regards
Shajee
October 8, 2019 at 2:22 am
charlietran
SubscriberHi, guys!
I want to do an impact simulation in ANSYS using Explicit Dynamics. When I remotely attached a point mass to the body surface, I encountered with an error: "Deformable behavior for remote entities is not supported in Explicit Dynamics systems. Please change such behavior to Rigid". But when i changed the point mass behavior to Rigid, another error occurred: "Could not transfer loads and constraints to the solver". What is wrong here? How do i do a simulation in Explicit Dynamics with a remotely attached point mass to body surface. Thanks in advance!
October 8, 2019 at 4:04 am
SubscriberCharlietran, Open a New Discussion to ask this question (or use Search). This discussion is marked as solved.
Then you can delete your post above.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2656
2120
1347
1118
461
