July 2, 2020 at 7:17 am
AndrewSmith
SubscriberHi,
I am trying to create a Design Point Service system that allows for access across networks for evaluators (ie. able to access computing power in a different location), however when running the DCS Host on my computer, the connection given is only a local one (127.0.0.1). I was hoping for some guidance on how to allow other users to connect via a URL or IP as I have not been able to find any resources on the topic.
Thanks,
Andrew -
July 3, 2020 at 1:15 am
tsiriaks
Ansys EmployeeHave you looked into these guides ?
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/dps_ug/dps_quick_start.html
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/dps_ug/dps_installation.html
Thanks,
Win
July 3, 2020 at 6:20 am
AndrewSmith
SubscriberHi Win,
As I am using an Academic license, I am not able to log into and view ANSYS Help with my account.
Thanks,
Andrew
July 6, 2020 at 11:40 pm
tsiriaks
Ansys EmployeeI'm not sure if the trick stated here still work
https://forum.ansys.com/forums/topic/links-to-help-go-to-customer-portal-sign-in-page/?order=all#comment-11d9a253-4840-4284-8b31-a94900ecd300https://forum.ansys.com/forums/topic/experience-our-new-online-help/?order=all#comment-edc2bafc-abf9-4e30-ad4e-a7fc0114d530https://forum.ansys.com/forums/topic/cutting-in-explicit-dynamics/?order=all#comment-7296e8ab-8a1b-492b-8d29-aa25006ac421
If not, you may need to find the ASC (ANSYS Support Coordinator) at your school and ask that person to login and download for you. This could be IT or someone in your department.
Thanks,
Win
July 9, 2020 at 9:01 am
AndrewSmith
SubscriberHi Win,
The trick worked! Thank you for that.
I will do some more research into the issue. I thought about it some more and I may have not set up ports on my router correctly to allow for connections so I will have to try that.
Thanks,
Andrew
July 9, 2020 at 9:01 pm
tsiriaks
Ansys EmployeeHi Andrew,
Good to hear. That sounds good, let us know how it goes.
Thanks,
Win
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5290
3311
2471
