November 29, 2022 at 1:01 pm
pavankonchada123
SubscriberHi Team,
Is there a tui command to create one stream line from inlet to outlet , for plotting the graph between velocity(y -axis) and length of streamline (x-axis)
November 29, 2022 at 4:26 pm
DrAmine
Ansys EmployeeYou can do that by using mass less particles and just inject single stream. Once it is there you can plot along it.
November 29, 2022 at 5:28 pm
pavankonchada123
Subscriberjust to reframe the question I have 5 outlets and wanted to plot velocity on stream lines starting from inlet to outlet1, outlet2, outlet3....outlet5. So total 5 streamlines with 5velocity plots
November 30, 2022 at 7:56 am
DrAmine
Ansys EmployeeYou can create the pathlines in Ansys Fluent and use the option "Reverse". There select the outlet(s) as source(s) for the pathlines.
2656
2120
1347
1118
461
