July 5, 2019 at 11:34 am
Inims
SubscriberHello,
Please carefully refer to the attached picture below for better understanding. I made plane surfaces using ''Point & Normal'' option and also without any option for my model herein attached. The Surface Planes cut-through other sections of the model which are not necessary for extracting report. For example, I need report only for A1 at the elbow but the Surface Plane created cut-through A2 and A3 as well. This also happened for the sections I marked B1&B2 and C1&C2. Please how do I create a Surface Plane that will not cut-through other sections of my model. Your help will be appreciated.
Thanks
Inima
July 5, 2019 at 1:42 pm
SubscriberHello Inima,
When the body is sliced with the plane to get A1, you end up with 4 bodies, but you only wanted 2 bodies.
Simply use Boolean Unite three bodies and that will get rid of A2 and A3 from the faces.
Regards
July 6, 2019 at 7:08 am
Inims
Subscriber@peteroznewman,
These surface planes were created in Fluent.
I think the boolean unite is done during geometry creation.
except similar feature is in fluent GUI but i can't find it.
July 6, 2019 at 10:50 am
SubscriberI wouldn't know where to find unite command in fluent either, maybe someone else will reply. You could make the surface planes in DesignModeler and do the slicing and uniting there.
3878
2639
1859
1262
606
