August 28, 2019 at 6:29 am
priyamguria
SubscriberI have a rotating heat pipe of 400 mm in length. I want to face split it for defining evaporator, condenser and adiabatic section of different length. how to do it?
August 28, 2019 at 10:18 am
SubscriberOpen the geometry in SpaceClaim, Click on Plane, click on centerline of pipe, click on Split Body tool and click on pipe then plane. Then go to the Workbench tab and click Share to have the two halves be connected during Meshing.
August 28, 2019 at 12:19 pm
priyamguria
SubscriberThanks for the solution. But this will split the body. I want to split the face.
August 28, 2019 at 1:49 pm
SubscriberThen click on the face and click on the Split tool.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2630
2106
1333
1110
461
