April 25, 2022 at 1:38 pm
AlexJohn
SubscriberI want to simulate heating of an object by several laser beams. Laser beams have Gaussian profile so to simulate heating I decided to apply heat flux with the table created by function editor. How can this tables be created by myself, w/o using of function editor?
Applied heat flux should be something like this
April 29, 2022 at 8:12 pmChandra Sekaran
Ansys EmployeeI am not aware of a way to create the function on the fly. You will have to use the 'Function Editor' to create the Table. But once created you can save it to a file. The equations are tough to decipher but potentially can be edited in this file. But if you are looking for a way to do this on the fly I am not sure function editor is the way to do it. On the other hand you can create multiple tables and superimpose them by creating duplicated layers of surf152.
Viewing 1 reply thread- The topic ‘Creating tables for heat flux’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
