Creating whole motor model by having fractional motor model
    • Shiva2810
      Hi
      I designed a motor using MotorCAD, and exported the Maxwell model from MotorCAD software. The resultant model in Ansys is fractional, but for my simulation, I need the whole motor model. I know how to do it using RMxprt file, but here is not available.
      Do you any solution to generate the whole model?
      Thanks in advance
    • Navya C
      You can export the full model in to Maxwell. You need to change settings in MotorCAD before you export the model.
      Go to Input Data Editor > Settings and change the symmetry to "Full machine"
      Regards
      Navya
    • halexahales
      thank you so much.
    • Navya C
      I have deleted your last comment as the link you posted is irrelevant to this discussion and against forum rules.
      Please check the links you are posting carefully from next time.
      Regards
      Navya
Viewing 3 reply threads
