3D Design
3D Design
Creation of Fluid Internal Boundary Condition In Discovery
    • alexander.c.canady
      I am trying to create a forced fluid flow inside a control volume that I have already generated. I tried to create and enclosure inside of an enclosure but this method was unsuccessful. Does anyone know if you can create an internal fan boundary condition, similar to what is possible in fluent? I would like to apply a forced fluid velocity to the 3 circular regions internal to the enclosure. Shown are the created enclosure and reigion where I'd like to create a control volume.
    • Devendra Badgujar
      It looks there is an SR raised for this request. We can continue this discussion over SR to avoid duplication and miscommunication.
      I understand that my colleage is helping with this issue. Let me check with her on this and you can continue the discussion with her. Thank you.
      Regards.
      Hi Devendra,
      I created this post because I have not received communcation from ANSYS yet regarding the open SR. Would you be able to convert this post into an SR? I am needing to run a simulation for this model ASAP. Thanks!
