Creation of new surface plane error
    • bmourad
      Please, if you have experience with Fluent, can you help?
      I am trying to create a new plane using Method "ZX Plane" in the Fluent Solution, not the Results. After selecting the Y value (e.g., 0.1mm) and creating the plane, it retrieves the default value (e.g., 0.2mm). I am not able to save the new Y value for the plane surface. I have tried the same for other Fluent models, and the same issue exists.
    • DrAmine
      Is it possible to create an iso-surface with y = 0.2 mm?
      Can you go to the Domain tab and post the Scale panel?
    • bmourad
      Thank you very much. Here is the screenshot.
    • bmourad
      Thank You very much. But I am wondering why the basic method of creating XZ surface plane is not saving the input value (Y).
      Not sure, planes have always been a little temperamental which is why most staff use iso-surfaces and we advise that as part of the training too.
    • bmourad
      Thank you very much. I will use the iso-surface in this case.
    • DrAmine
      Great!
Viewing 7 reply threads
