September 5, 2019 at 7:38 am
Oelot
SubscriberHi, I'm trying to study the creep for a tensile specimen, but my solution does not converge.
I turned on Newton-Raphson residual plots to see what happen (http://www.padtinc.com/blog/overcoming-convergence-difficulties-in-ansys-workbench-mechanical-part-i-using-newton-raphson-residual-information/
I have this (the problem is on the surface where the force is applied. )
I'm thinking about the problems, maybe my Norton's creep parameters are wrong, I calculate them from a curve :
Norton Law : creep strain rate = A* sigma^n * time^m
I deduced the 1st creep parameter is A, the second is n, and the third is m in the engineering data.
And the value I found for them are :
1st = 0,25, 2nd = 20,58 and third = 1, I put these value in the engineering data.( are they realistic ? )
NB : I did a simple tensile test, by putting a fixed support in one side, and by applying a force in the other.
Thanks you
September 5, 2019 at 12:51 pm
You don't have the equation for Norton correct. See the post I linked to.
Creep constants depend on the Units you are in. You need different constants if you are in psi than if you are in Pa or MPa.
March 19, 2020 at 9:00 am
gopikrishna
Subscriberi need to simulate a round bar for creep in which one end is fixed and other is applied by a tensile load. the problem is my simulation is not converging. i have tried changing substeps, applied fine mesh, rechecked creep constants and units still problem exists. please help me to sort out this problem.
https://forum.ansys.com/forums/topic/unable-to-converge-creep-simulation-in-workbench/
March 19, 2020 at 12:48 pm
SubscriberOkay, I will lock this Discussion and anyone can reply to your discussion linked to above.
2098
1323
1108
461
