Creep integration algorithm did not converge for element
    • HBaji
      I have a simple model with a single element to test plasticity and creep of PLANE182 elements to be used for concrete. For plasticity Menetrey-Willam material is used and for creep implicit model 6 is used. The model runs fine for plasticity and creep if they are not run simultaneously.
      Once they are combined the warning " Creep integration algorithm did not converge for element" and the model does not run. The input file is as follows,
      FINISH
      /CLEAR
      /TITLE, Menetary-Willam Test With Creep
      Fc = 30.0
      ft = 3.0
      Ec = 30000
      Nuc = 0.20
      ec0 = 0.002
      etu = 0.002
      ! Model Geometry
      /PREP7
      ! ELASTIC CONSTANTS
      MP, EX, 1, Ec
      MP, NUXY, 1, Nuc
      TB, CREEP, 1, 1, 4, 6
      TBDATA, 1, 0.1058*2.35/Ec, 1, -0.8575, 0
      ! Base Menetrey-Willam concrete
      Rc = Fc         ! uniaxial compressive strength
      Rt = ft         ! uniaxial tensile strength
      Rb = 1.20*Fc    ! biaxial compressive strength
      psi = 33        ! dilatancy angle
      ! Linear hardening softening
      omega_ci = 0.33
      omega_cr = 0.20
      kappa_cm = ec0 - Fc/Ec
      kappa_cr = 0.008 - omega_cr*Fc/Ec
      omega_tr = 0.20
      kappa_tr = (1.0 - omega_tr)*etu
      TB,CONCRETE,1, , , MW
      TBDATA, 1, Rc, Rt, Rb
      TB,CONCRETE,1, , , DILA
      TBDATA, 1, psi
      TB,CONCRETE, 1, , , HSD6
      TBDATA, 1, kappa_cm, kappa_cr, omega_ci, omega_cr, kappa_tr, omega_tr
      ET, 1, PLANE182
      KEYOPT, 1, 1, 0
      KEYOPT, 1, 3, 0
      KEYOPT, 1, 6, 0
      ! Nodes
      N, 1, 0, 0, 0
      N, 2, 1, 0, 0
      N, 3, 1, 1, 0
      N, 4, 0, 1, 0
      ! Concrete Element Generation
      TYPE, 1
      MAT, 1
      EN, 1, 1, 2, 3, 4
      ! Support
      D, 1, UX, 0
      D, 1, UY, 0
      D, 4, UX, 0
      FINISH
      /SOLU
      SOLCONTROL, ON
      NLGEOM, ON
      RATE, OFF
      TIME, 1e-8
      F, 2, FX, -3/2
      F, 3, FX, -3/2
      SOLVE
      NSUBST, 100, 1000000, 100
      NEQIT, 100
      OUTRES, ALL, ALL
      RATE, ON
      TIME, 5
      SOLVE
      FINISH
      I am not even sure if ANSYS can combine the Menetrey-Willam plasticity and creep.
      Any help is appreciated.
Viewing 0 reply threads
