June 26, 2020 at 2:30 pm
supercars2
SubscriberImporting assembly from PTC/Creo including assembly features (assembly cut): Instead of removing material, Spaceclaim adds the feature as a part named "SPACutx_partnumber", see attached picture.
A possible solution is to delete the part named "SPACut..." but then the assembly cut material is not removed.
June 27, 2020 at 1:59 am
SubscriberExport a Parasolid or STEP file from Creo, then the assembly cut will be in the exported geometry and you can import that into SpaceClaim.
June 27, 2020 at 9:42 pm
supercars2
SubscriberWorkaround was fine, thanks. I would prefer importing native files so I will report the issue to ANSYS. But thx anyway.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3636
2502
1729
1222
578
