December 8, 2020 at 3:16 pm
moranlouie
SubscriberThis is using an S2S radiation model. I can't find, in the boundary conditions, how to set-up this critical zone.
December 8, 2020 at 3:47 pmDrAmine
Ansys EmployeeYou did not specify the critical zone. Critical zones are the zones which are marked as very important for Radiosity Calculation and View Factors pre-caclulation. Show your S2S Panel.nDecember 14, 2020 at 7:22 amDecember 14, 2020 at 11:37 amRob
Forum ModeratorCan you also post the vf panel(s). If you compare the S2S model limitations with your setup are there any conflicts?nDecember 14, 2020 at 1:13 pmDrAmine
Ansys EmployeeUnder setting you will see further options. One of them is regarding manual or automatic clutsering.nViewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
8740
4658
3151
1678
1452
