May 26, 2022 at 3:12 am
Rosmin_Elsa_Mohan
SubscriberHi Team,
I would like to make a cross resonator (photo attached) by varying the vertices of a polygon geometry. Is it possible to make this cross shape from a single polygon geometry by adding in the vertices? Does the order in which the vertices are defined affect the final shape?
Also, while using the sweeping tool - how can we select individual vertices of the polygon to sweep ? I was able to select vertices but unable to view the vertices defined.
Thanks,
Rosmin
May 26, 2022 at 3:27 am
Rosmin_Elsa_Mohan
SubscriberImage is taken from a manuscript - Physical Review Letters ┬À July 2011, DOI: 10.1103/PhysRevLett.107.045901
May 26, 2022 at 3:52 pm
Guilin Sun
Ansys EmployeeYes, you can use polygon to create such object. The script can be like:
n_sides=12;
V=matrix(n_sides,2);
V(1:n_sides,1)=[9,1,1,-1,-1,-9,-9, -1,-1, 1, 1,9]*1e-6;
V(1:n_sides,2)=[1,1,9, 9, 1, 1, -1,-1,-9,-9,-1,-1]*1e-6;
then you will need to add its z and zspan, and its material.
I would suggest to have the points clockwise or counter-clockwise, in order to avoid any mistakes.
If you want to change any of the coordinate point, currently you have to redraw it, and delete the original one.
May 27, 2022 at 4:38 am
Rosmin_Elsa_Mohan
SubscriberThanks for the reply. It was helpful.
- Error on Lumerical device
3744
2573
1821
1236
594
