October 2, 2018 at 2:54 pm
October 2, 2018 at 6:52 pm
SubscriberHello Sam,
Try exporting an IGES file from AutoCAD and opening the IGES file in SpaceClaim.
The problem is an AutoCAD is a 2D drafting program and a single file can contain many views, and when you export the entire file, you might end up with a mess in SpaceClaim. The AutoCAD experts at your company probably know how to export a single view out of a large drawing and put that in a separate file.
Put the IGES file inside a zip archive and attach it to your reply if it didn't go well.
October 2, 2018 at 7:30 pm
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
