Discovery Import
Discovery Import
Cross-section: remove unnecessary lines
    • papp
      I'd like to remove the not required lines from cross-section images (taken by using the Cutplane tool in Discovery Live). To be more accurate, the lines in the fluid body are incorrect and unnecessary, as no solid object is there.
      Please describe a method of removing these lines, or suggest another solution to visualizing the flow and temperature fields around complex objects in a similar and appealing way.
      Thanks,
      Bálint
    • Subashni Ravichandran
      Hi  Bálint Papp
      Please try turning off the enclosure. The cross-section lines appear as it considers the enclosure as a solid.
    • papp
      Subashni
      What you suggest is rather logical, and it works perfectly. Thank you :)
