June 29, 2023 at 1:00 pm
Levente Bicskei
SubscriberDear Forum,
I would like to create a simple sample simulation of cryogenics cooling. Just a pipe with one inlet, one outlet.
How can I create a new material in the temperature range of 10-50 K?
I tried copying an existing gas and manually modifying the material properties, but it seemed to only work down to 100 K. From measurements I have the data-points for temperature-viscosity, temperature-density, etc pairs. I want to create a new material from these, but I only saw polynomial options in the basic ansys material data file.
Otherwise, I have 40 pairs of points (10-50 K with 0.1 K step size)
Thank you for your help!
June 30, 2023 at 11:42 am
Prashanth
Ansys EmployeeHello,
That is very high no of data points. Easy way would be to curve fit the graph in excel (or matlab etc.) and get a polynomial of some order. Input that polynomial to the material panel.
June 30, 2023 at 12:12 pm
Levente Bicskei
Subscriber -
June 30, 2023 at 12:25 pm
Prashanth
Ansys EmployeeI think the values here are just to visualize the graph, at different ranges. It's okay if it defaults to a value.
7578
4424
2949
1422
1322
