CuCrZr alloys
    • GeeMechanical
      Is there any way to change the composition of any alloy (especially copper,  alloy) in ANSYS - Static Structural or any other sub-programmes?
      Can I observe the changes in the mechanical and physical properties of those alloys?
    • peteroznewman
      Static Structural doesn't use any details about the composition of an alloy.  It uses measured physical or mechanical properties that are input to the Engineering Data record such as Density or Young's Modulus.
      You can name the material or add a description with the alloy composition to help you remember one material from another.
