November 16, 2023 at 9:57 am
cbur
SubscriberHello,
One of our customers has an activation problem for discovery.
He receives the error : "Curl Error (6) Couldn't resolve host name - Could not resolve host: ansys-fno.flexnetoperations.com"Do you have any information about this error code? What could it be?
(I can send you the .ansys file containing the logs in a private message if you need it).
Thanks
November 20, 2023 at 4:28 am
Charudatta Bandgar
Forum ModeratorHello cbur,
Please go through the Discovery License Activation Troubleshooting
Can you please check if your firewall is not stopping any of the operations? Try again by disabling your firewall and see if it helps.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
