May 22, 2022 at 1:30 pm
May 23, 2022 at 4:12 am
andy.zhou.nuaa
SubscriberCould u tell me which area u need show current flow?
May 23, 2022 at 6:06 am
foXSers
SubscriberFirst, I'll describe the process a little bit. In general, this is a 3D structure through which I pass the current. There are two silver plates at the ends, and between the plates there is a 3D structure through which I need to see the current flow.
The blue arrows indicate that I need to see the current flow in the 3D structure. Thanks in advance for your help!
May 24, 2022 at 5:44 am
May 31, 2022 at 4:19 pm
June 1, 2022 at 4:53 am
foXSers
SubscriberThank you so much!
- Maxwell, HFSS or Q3D?
- Error
3812
2593
1849
1244
600
