TAGGED: chaboche, curve-fitting, kinematic-hardening, metal, plasticity
November 12, 2020 at 9:43 am
AbelBerhanemeskel
SubscriberHello Everyone,
I was trying to model cyclic plasticity using chaboche Kinematic hardening model. I noticed that when you input a chaboche Kinematic hardening model a curve fitting option becomes available. When you include the curve fitting option a uniaxial plastic strain test data input area where it says add experimental data becomes available. Can anyone please explain to me how I can input the uniaxial plastic strain test data and how I can get the chaboche parameters?
Thanks.
November 22, 2020 at 6:31 pmViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- Material library
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- About Bilinear Isotropic Hardening Plastic Model !
8762
4658
3151
1678
1456
