August 7, 2019 at 11:02 pm
EM_Design
SubscriberI have problem with (probably) meshing an object that is buried in a rotor. if I put that curved object at the head of the rotor, it does work but if I bury it in the rotor, it gives me the following error when I apply mesh operation: Failed to recover outlines. please see the object in the attachment. The head object doesn't have any issue. The inner object in the rotor causes the mentioned issue, if it is curved as you see. However, If I change that to straight line object (rectangular), the mesh operation does work.
August 7, 2019 at 11:36 pm
SubscriberI don't mesh for EM models, so I just throw this out as something to try and see if it helps.
Split the body down the center and put the two bodies into a multibody part to share topology.
That way, the "buried" cavity will be exposed to the new cut plane and might allow the meshing to succeed.
August 8, 2019 at 2:30 pm
EM_Design
SubscriberI tried your method and split the body into 10 pieces but still the same error. I feel there should be a setting in mesh for this problem
August 16, 2019 at 6:51 pm
Paul Larsen
Ansys EmployeeSwitch from TAU to Classic mesher. Go to the menu Maxwell 2D > Mesh Operations > Initial Mesh Settings, and select Classic. This will remove that error message. There are some other methods to fix this, but this is the easiest.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2610
2088
1319
1108
459
