May 10, 2022 at 3:47 am
jperez683
SubscriberHi all,
I went through the Rmxprt design without any issues for a PMSM, however I did not see where or how to add features to the stator laminations that are outside of the slot dimensions. Essentially, I am trying to add radial holes between the slots and stator OD. These features would change the losses calculations so it's important for me to include it in my model.
Conversely, could convert the design to maxwell 2d. Edit the model, then send it back to rmxprt?
May 11, 2022 at 11:55 amNavya C
As RMXprt is a template-based design tool, I don't think there is an option to add the customizations that you want to do.
You can create the Maxwell design from Rmxprt and add the necessary customizations in the Maxwell and analyze your model for more accurate results.
There is no option to send it back to RMXprt.
Regards Navya
Viewing 1 reply thread- The topic ‘Custom Laminations in Rmxprt’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1688
1478
