Custom materials crashing
    • reubeni100
      Hi all, hoping someone may be able to help me out with an issue I'm having. I'm trying to create a custom material library in my engineering database in Ansys. I've made a new data source but every time I try to create a new material workbench crashes when I start adding material properties, specifically Poisson ratio under Isotropic Elasticity, other properties such as density I can enter no problem but this specific property crashes workbench every time.
      For reference I'm using workbench 2020 R1 on windows 10
      If anyone has any suggestions I'd greatly appreciate it. Thanks!
    • cgwood2
      I am also having this issue. As soon as the Poisson's ratio is entered, the entire project crashes. nHelp would be appreciated.nThank you.n
    • Gary Stofan
      Hellon We had some defects with Engineering Data when the Beta features were enabled. Are your Beta features enabled?nAlso, we had reports of issues with non-US locale decimal separators. Dot/period is OK, but comma or other may cause Workbench to crash.
