April 7, 2023 at 5:56 am
Sai Manikanta Kaja
SubscriberHi,
I am new to using Ansys fluent and am working on a project of flow through a pipe where I need to initialise the solution with a custom flow field (Pressure, x,y,z velocities) which will be derived from another method. Looking to know if it is possible to do and if yes, how to start ?
Thank you
April 10, 2023 at 7:58 pm
Federico Alzamora Previtali
SubscriberHello,
you can initialize the flow from boundary values or you can use the Patch function to set values for selected flow variables in a given cell zone or cell register.
33.9. Initializing the Solution (ansys.com) -
April 11, 2023 at 9:58 am
Ansys EmployeeYou may also want to review the interpolation file. Use a simple (small) model to understand the format.
5268
3299
2469
