August 24, 2019 at 2:33 am
cbliss1
SubscriberHello,
When using the multiphase VOF method along with the built in evaporation-condensation lee model, is there a way to implement exactly what is being done in the built in model but with a UDF. The only portion of this built-in model I need to change are the evaporation and condensation frequencies which I would like to customize based on calculated parameters that change with the simulation.
So, is there a UDF macro that is being used to implement this exact built in process? I believe it can be done with DEFINE_MASS_TRANSFER, where I would just change the 0.1 values used by default. but is there more to it than this?
February 10, 2021 at 7:43 am
Nitin_Bansal
Subscribernhello,nare you able to resolve your above mentioned problem. i have no idea that how to decide the values of evaporation and condensation frequencies.nthanksn -
February 10, 2021 at 8:32 am
DrAmine
Ansys EmployeeI guess it is better to create a new thread where you add more info about your case.
2656
2120
1345
1118
461
