Customized Result Based on Von Mises Stress
    • Husain_53
      Dear Friends,nRelated on topics (https://forum.ansys.com/discussion/23188/ansys-vs-asme-b31#latest), I got some following issues about Ansys Result vs ASME B31nnWhich are more reliable, using Principal Stress (Normal Stress) or using customized result bsen on Von Mises (Von Mises stress divided by 2)?nHow to create customized result based on Von Mises Stress. It is need to divide the Von Mises result by 2nnThank you in advancenHusainn
    • Aniket
      To answer your second question (can't comment about first!), you can simply assign an identifier (lets assume myEqv) to an equivalent result object and insert another user-defined result with expression = myEqv/2 to get the desired result or you can create an ACT app to calculate desired custom results as explained in https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v211/en/act_cust_mech/act_Mech_FeatureCreation_Postprocessing.html, but in my opinion that would be an overkill if simple identifier + user defined result can work in your case.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forum
