Preprocessing
Preprocessing
Cut cell meshing
    • Andrea159357
      Hello, i'm trying meshing with assembly cut cell but i have got some warning. "The tolerance of the geometry is larger than the applied tessellation refinement tolerance. This might lead to an uneven mesh and/or to poor geometric accuracy of the mesh."
      How to solve this warning?
      In second place, inflation layer keep failing.
      Can someone help me?
    • Keyur Kanade
      you will need to changes some sizes. please use some coarse sizes and check.
      usually i go for tetrahedron mesh and if required, i convert them to poly in fluent.
