3D Design
3D Design
Cut solid with another solid in DM
    • mekafime
      Hi everybody,
      I try to cut horizontal solid with vertical solid (has a radius), what tool i can use?
      Thanks.
    • peteroznewman
      Boolean Subtract.n
    • mekafime
      Hi Peter,nthe tool doesnt work, both solids havent interference, I try to cut the lower solid with the projection of the upper solid.n
    • peteroznewman
      Extrude the Face from the upper solid so that it interferes with the lower solid, then use Boolean Subtract.n
Viewing 3 reply threads
