June 5, 2023 at 6:38 pm
javat33489
SubscriberHey everyone, I'm trying to cut the top of the LS-DINA WORKBEnch. The grid behaves not physically why?
I am using materials from the database:
There are other questions:
- If I choose a rigid drill body, then the joint is not available for it and I cannot move it. Therefore, I added another three 000 to the steel density of the sverd so that it does not deform.
- The grid behaves not physically why? I want a piece to come off.
- I set the movement along the X axis along the corresponding axes 0, but for some reason the drill still rises.
Here are my settings, I also attached the archive below:
June 7, 2023 at 1:12 pm
Ram Gopisetti
Ansys EmployeeHi ,
that material do not have nay damage or the eps to fail an element hence you are seeing such issues, ideally, you want to simulate these process uisng SPG or EFG methods than Lagranginan elements
cheers, ram
June 8, 2023 at 2:28 am
javat33489
SubscriberThe workbench has a bug, which does not allow particles of SPH or SPG to be fixed in space.
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7742
4502
2957
1449
1322
