February 25, 2022 at 1:06 pm
crf202589
SubscriberHi I am Rupesh kumar, M.tech student , IIT Delhi. while doing my thesis work under prof. Samaresh Das, i need to plot cv characteristics for my structure. For the reference i have referred on of the exapmle given on Ansys portal ----> https://support.lumerical.com/hc/en-us/articles/360042328674. Upon running the .ldev i got charge chrage.mat file stored in same location in which file is saved and then running the PN_phase_shifter_CHARGE.lsf file i am getting this error -----> Can not find result 'total_charge' in the result provider 'CHARGE::monitor_charge' .
kindly help me out with it
February 25, 2022 at 8:06 pmFebruary 26, 2022 at 9:23 amcrf202589
SubscriberI am using ANSYS Lumerical 2021 R2 Finte Element IDE --- latest version only still getting this error and also while exporting np density(CHARGE : chrage) no option for .mat export although i can extract .mat file for anode current vs volatge . kindly help me out with it
February 26, 2022 at 6:26 pmGuilin Sun
Ansys EmployeePlease check the Result View once clicking the monitor, as shown previously.
February 28, 2022 at 9:26 amcrf202589
Subscriberwhile exporting the .mat file from np plot ---> total _charge visualization window ,i am getting an error ," cannot open a connection to MATLAB , you must use a supported version" . I am using Matlab R2021a version ,and Ansys lumerical R2021 . Kindly help
February 28, 2022 at 9:27 amcrf202589
SubscriberAttachement for the error
February 28, 2022 at 4:15 pmGuilin Sun
Ansys EmployeeThis is a different issue. Usually if you do not open matlab file, but just export data, it does not need matlab to be connected. Please try to test
xyz=1;
matlabsave("test1.mat",xyz);
to see if it works.
For matlab connection, please refer this post https://forum.ansys.com/discussion/comment/140905#Comment_140905
Viewing 6 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2600
2088
1319
1108
459
