March 16, 2022 at 4:09 am
iqnlo
SubscriberHi there
I am doing mode convergence test for my own design of edge coupler. But I found that the mode didn't converged. When I was using CVCS at the taper structure region and the energy conservation setting is "make passive"
I'm using the codes from this page: Convergence testing process for EME simulations – Lumerical Support
First of all, I applied this script on your official edge coupler: Edge coupler – Lumerical Support
March 16, 2022 at 4:13 amiqnlo
SubscriberBy the way, I recently noticed that the result from the CVCS one is relatively converged except for some noise.
So shall I take the 60 modes as where the modes start to converge? The noise are because there are too many modes as said in the tutorial. So maybe I can ignore the noise and view this as a good result?
Thanks! I'm looking forward to your comment.
Best wishes
March 23, 2022 at 12:01 amTaylor Robertson
Ansys EmployeeThis perturbation to the S matrix arises due to energy conservation and CVCS being used. I would direct you this video for an explanation of what is going on here.
https://support.lumerical.com/hc/en-us/articles/360045466833-Convergence-Testing-Too-Many-Modes
You may need to increase the number of cells to get the convergence to behave better. Although convergence becomes more difficult using CVCS and energy conservation would ideally make the results more accurate. Make passive may be the best option for this type of situation. To understand where the problem is coming from you may want follow the procedure outlined in the link below.
https://support.lumerical.com/hc/en-us/articles/4412892724243-EME-Convergence-Testing-An-Intuitive-Approach
Best
- Error on Lumerical device
2524
2066
1279
1096
457
