December 8, 2022 at 5:15 am
Ivan Mendez
SubscriberHey all, I have a csv that contains the x,y,z coordinates of points on my geometry. I found that I can find the cell that contains that point using CX_Find_Cell_With_Point. However, I also found CX_Find_Closest_Cell_To_Point in the cxndsearch.h header. What are the differences between the two, and what does "double *dist" mean in the CX_Find_Closest_Cell_To_Point argument?FLUENT_EXPORT CX_Cell_Id *CX_Find_Cell_With_Point(ND_Search *, double v[3], double time);FLUENT_EXPORT CX_Cell_Id *CX_Find_Closest_Cell_To_Point(ND_Search *, double v[3], double *dist, double eps); -
December 8, 2022 at 10:25 am
Ansys EmployeeAs a guess (I'm not allowed to comment on macros that aren't in the UDF manual) the macros will return the cell if the point is in it, the Closest macro will do some checks incase you've missed the meshed domain.
In C coding "double" calls double precision, ie more significant figures are stored. If a mesh is very fine or the cells small a distance might return zero without the extra accuracy.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2508
2064
1277
1088
456
