February 23, 2022 at 1:54 pm
vytautas
SubscriberDear, Experts
I have question regarding aero damping analysis:
it was made modal analysis of propeller, it deformation was exported to cfx, made aero damping analysis according : https://www.singularityeng.com/singularity-engineering-blog/2019/1/8/predicting-damping;
but results of aero damping curve show instability? (show in black color), however in example (last picture) no jump
More time steps require
Normalization made according example settings - work with this value?
Thank You for help;
February 26, 2022 at 2:47 amrfblumen
Ansys EmployeeWhen we evaluate aerodynamic damping for a given operating condition, frequency and nodal diameter, we need to ensure that the simulation is converged and has reached a time-periodic condition. For a converged, time-periodic solution, it's expected that the value of aerodynamic damping will be varying within a small range over the period of oscillation. From your charts of aero damping versus accumulated time step, the damping hasn't settled down. This may due to:
-Set up issues. I would review your set-up to make sure there are no errors.
-Convergence issues. Make sure the model is converging at every time step and the run is becoming time-periodic. It looks like in your case you only ran it three periods (similar to the example case you mentioned). It may take several more periods to become time-periodic. You might want to look at CFX Tutorial 36 (Fourier Transformation Method for a Blade Flutter Case). Although in your case you're not using the Fourier Transform method, The other parts of the setup should be similar. In the tutorial, the model is run a sufficient number of periods such that the solution is time-periodic.
March 1, 2022 at 11:22 amvytautas
SubscriberThank You for answer;
regards;
2656
2120
1345
1118
461
