December 16, 2019 at 7:31 am
talhaensar
SubscriberHi,
I conducted a cyclic symmetry structural anslysis. Then, I implemented small geometrical changes but there is no any axis change or geometrical movement. When I run cyclic symmetry structural analysis with updated geoemtry, I get an error as shared below;
"Newton-Raphson iterative solution is not available for cyclic symmetry analysis (CYCLIC command) with non-cyclic loading."
I changed solver with direct method, but the situation is the same. Analysis can run only when I suppress rotational velocity.
I will appreciate it ifyou can provide any solution.
Thanks in advance,
Talha
3419
2475
1310
1022
