October 17, 2018 at 12:40 pm
sohrab
SubscriberHi everybody,
I am developing an APDL code for crack growth analysis. I am confused with loading. my model would be 2D and method to analyse crack growth would be XFEM.
I use
nsel,s,loc, Y, 100
sf, all, pres, -10
allse
and also
antype,0
time, 1.0
deltim, 0.25, 0.25,0.25
outres,all, all
My question is: how many cycles the loading would be continue? (above mentioned is a 10 Mpa pressure with 0.25 frequency and also 0 stress ratio) and how can I control this loading until crack reaches a specific length?
I in my analyses cycle of loading reaches to 10^8 orders
I appreciate your helps and comments in this regard.
October 17, 2018 at 3:36 pm
Sandeep Medikonda
Ansys EmployeeSohrab,
Can you please refer to section 3.6 and 3.7 of the 19.0 Fracture Analysis Guide that cover XFEM based crack growth analysis?
Sandeep -
October 25, 2018 at 6:49 am
sohrab
SubscriberThank you Sandeep for your reply.
I once more looke in detail section3.6 but my question is unsolved yet.
the question is that how many cycles APDL runs the simulation?
when i plot the crack extension vs cycles only to specific amount of crack extension the analysis continues (depends on element size of crack region) in my case 0,48 mm . but there is no control to continue simulation to an specific amount.
October 31, 2018 at 3:01 pm
David Weed
Ansys EmployeeHi Sohrab,
You can stop crack growth at a specified value using the CGROW,STOP command:
Command Specification for
Action
= STOP
CGROW, STOP,
Par1
,Par2
Par1
CEMX -- Stops the analysis when the crack extension for any crack-front node reaches the maximum value (specified via
Par2
Par2
Value of maximum crack extension allowed.
help link: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_cmd/Hlp_C_CGROW.html%23CGROW_STOP
2104
1327
1110
461
