Cylindrical axisymmetrical external data importation
    • biocou
      I need to import data which are axisymmetrical. So i uploaded data in one radius.
      Experimental data is axisymmetrical which means that source N1 is the center and i need to have the same distribution in all directions (rotation around the center)
    • Govindan Nagappan
      @biocouHi Array nFor 2d(axisymmetric) to 3d mapping , you need the imported data to have X and Y coordinates and corresponding load values. In External data, make sure you specify 2D for dimension. You can ignore unavailable datanYou should see 2D projection option when importing 2D datann
