September 1, 2022 at 5:51 am
verners
SubscriberHello,
further comments on this post
https://forum.ansys.com/forums/topic/damorph-failure/
would be appreciated (a new comment was added).
September 6, 2022 at 6:48 pm
Bill Bulat
Ansys EmployeeI probably haven't used this command for over twenty years. It's hard to figure out how to use it effectively. As I recall, it is used in conjunction with the now undocumented PHYSICS command. Although undocumented, the PHYSICS command still works at 2022R1 (the most recent release I have tested). DAMORPH is probably not a good way to go if your objective is to simulate pull-in of a capacitively induced MEMS device (e.g., RF switch). For that, I would use coupled field PLANE223 with keyopt(1)=1001 and surface-to-surface contact elements with CNOF (contact normal offset) real constant to prevent complete closure of gaps (which would cause an element formulation error).
If you copy the following APDL into an input file and read that input file into MAPDL, you should have a working example of DAMORPH. Electrostatic and structural analyses are done sequentially (load vector coupling via LDREAD). The electrostatic mesh is then morphed via DAMORPH. A second sequence of electrostatic-then-structural calculations is made with the morphed mesh, and the electrostatic mesh is morphed again.
fini/cle/pnu,mat,1/num,1/sys,del *.ph/sys,del *.pngC********************************************C*** PARAMETERS (MKS)C********************************************l=0.00075 ! DOMAIN LENGTHh=0.0002 ! DOMAIN HEIGHTl_elctrd=0.0005 ! ELECTRODE (BEAM) LENGTHt_elctrd=0.000005 ! ELECTRODE THICKNESSgap0=0.00003 ! INITIAL GAP UNDER ELECTRODEE_elctrd=2e10 ! ELECTRODE ELASTIC MODULUSV_elctrd=150 ! ELECTRODE VOLTAGEesz1=gap0/2 ! MESH SIZEC********************************************C*** GEOMETRYC********************************************/prep7asel,nonerect,,l,,hcm,scrap_a,areaasel,nonerect,,l_elctrd,gap0,gap0+t_elctrdaatt,1,,1cm,elctrd_a,areaallscmse,allasba,scrap_a,elctrd_a,,dele,keepcmse,u,elctrd_aaatt,2,,2cm,air_a,areaC********************************************C*** ATTRIBUTES, MESHC********************************************et,1,183,1mp,ex,1,E_elctrdet,2,121mp,perx,2,1msha,1allsesiz,esz1ames,allC********************************************C*** BCsC********************************************esel,s,mat,,1nsleesel,s,mat,,2nsle,rcm,V_elctrd_n,nodenslensel,r,loc,xcm,d_elctrd_n,nodensel,s,loc,yd,all,voltallscmse,alld,d_elctrd_n,uxd,d_elctrd_n,uyd,V_elctrd_n,volt,V_elctrdesel,s,mat,,2cmse,s,V_elctrd_nsf,all,mxwfC********************************************C*** PHYSICS ENVIRONMENTSC********************************************allssave,both,dbet,1,0nlge,offphysics,write,es,es,phresu,both,dballssfede,all,all,mxwfet,2,0nlge,onphysics,write,struct,struct,phfiniC********************************************C*** SOLVEC********************************************/soluphysics,clear ! ELECTROSTATIC SOLVEphysics,read,es,es,phsolvfini/post1plns,volt/sho,png $plns,volt $/sho,close $/wait,2fini/soluphysics,clear ! STRUCTURAL SOLVEphysics,read,struct,struct,phasel,s,mat,,1alls,belo,arealdread,forc,,,,,file,rthsolvfini/post1plns,u,y,2/sho,png $plns,u,y,2 $/sho,close $/wait,2finiC********************************************C*** MORPH ELECTROSTATIC MESHC********************************************/prep7alls!physics,clear!physics,read,es,es,phddel,all,allsfed,all,all,mxwfet,2,121asel,s,mat,,2damorph,air_a !,,1/edg,1,0eplo/sho,png $eplo $/sho,close $/wait,2finiC********************************************C*** SECOND SOLVE WITH MORPHED MESHC********************************************/soluphysics,clear ! ELECTROSTATIC SOLVEphysics,read,es,es,phsolvfini/post1plns,volt/sho,png $plns,volt $/sho,close $/wait,2fini/soluphysics,clear ! STRUCTURAL SOLVEphysics,read,struct,struct,phasel,s,mat,,1alls,belo,arealdread,forc,,,,,file,rthsolvfini/post1plns,u,y,2/sho,png $plns,u,y,2 $/sho,close $/wait,2finiC********************************************C*** SECOND MORPHING ELECTROSTATIC MESHC********************************************/prep7alls!physics,clear!physics,read,es,es,phddel,all,allsfed,all,all,mxwfet,2,121asel,s,mat,,2damorph,air_a !,,1/edg,1,0eplo/sho,png $eplo $/sho,close $/wait,2fini/eofRegards,Bill -
September 8, 2022 at 6:11 am
verners
SubscriberHello,
thank you for the script. Additionally I would like to ask if the PHYSICS command is a prerequisite for using DAMORPH correctly.
Best regards,Osvalds
September 28, 2022 at 8:00 am
verners
SubscriberPS: apparently the critical detail that was missing in my earlier script was shared lines between the structural and non-structural regions
2156
1359
1150
462
