March 7, 2022 at 10:42 am
Guillaume ANFOSSI
SubscriberHello,
Is the module Data Exchange PDF used by SpaceClaim Engineer still available with the new versions of ANSYS SpaceClaim?
March 7, 2022 at 10:54 am
Subashni Ravichandran
Forum ModeratorHello GUICAD
I'm not quite sure I understand your query correctly.
Can you please explain what you mean by data exchange pdf?
March 7, 2022 at 11:01 am
April 6, 2022 at 12:00 pm
You can simply Save As > PDF Facets, the resulting file will be a 3D PDF. In SC Options > File Options > PDF, you can change the format of imported 3D PDFs (facets, solid/surface body).
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7646
4468
2957
1427
1322
