March 22, 2022 at 6:26 am
Mariah Ha
SubscriberHi,
I am trying to extract the data (matrix) of the electron and hole current densities (Jn and Jp) from the charge visualizer, as shown below. The "view data" option gives just a slice of the data. The "export to text" option also does not give all the magnitude matrix of Jn , as shown in the picture. I am looking for the whole matrix to perform some calculations, not a slice. I did not understand the meaning of x(7616,1,1) in the extracted text file. Can you please help me ?
March 22, 2022 at 7:23 pmGuilin Sun
Ansys EmployeeI guess you are using CHARGE, which uses finite element mesh. Therefore, the dataset is not like the rectilinear FDTD mesh.
You can get the result from CHARGE object:
Charge=getresult("CHARGE","charge");
Jp=Charge.Jp;
Then you will need to interpolate the Finite Element mesh into rectilinear result. Please refer this example:
interptri - Script command - Lumerical Support
interptet
Please follow the examples and write your own script.
If you have scripting questions, please write a separate post.
- Error on Lumerical device
2630
2104
1329
1110
461
