August 27, 2023 at 3:06 pm
Yossi Abutbul
Subscriberis it possible to obtain voltage drop in q3d?
August 29, 2023 at 8:09 am
Sriparna
Ansys EmployeeHi Yossi,
You can see several field plots in Q3D. Directly you cannot plot the voltage drop in Q3D. You can edit current sources to compute voltage drop using the Resistance Matrix which you get from Q3D. For better understanding, Please refer to Resistance Matrix in the Technical Note of Q3D Extractor Help (ansys.com)
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7646
4468
2957
1427
1322
