March 17, 2021 at 3:26 pm
sridharsahoo366
SubscriberI am simulating an internal combustion engine using ansys Forte. The simulation starts from 5° CA before the intake valve opening to 5° CA after the exhaust valve opening. However, when the intake valve open crank angle reaches, the deadlock in MPI communication for the job occurs. Thereafter simulation stops at that crank angle.
I am unable to understand the possible reason for this error.
March 19, 2021 at 3:32 pmRK
Ansys EmployeeHello, nThis error usually ocurs when you are running on fewer cores. Please use larger number of cores and try again. Let us know if the issue persists. nMarch 30, 2021 at 8:55 amsridharsahoo366
SubscriberI am running my simulation in an HPC server, where I am using 80 core on 2 nodes. Please suggest hownto resolve this issuenI guess the issue cause due to the mesh problem at the intake valve opening. Sometimes, I get different errors at this crank angle like below.nError in creating auto meshnAssertion failed: RegionController.cpp:330nCGNS solution file closed successfullynn
2656
2120
1349
1118
461
