November 14, 2018 at 3:36 am
Khurram
SubscriberHow to decrease the nodes size and increase the elements size in latest version of Ansys(fluent)?
November 14, 2018 at 4:43 am
Keyur Kanade
Ansys EmployeeCan you please explain the question? Can you please insert images as we can not download attachments.
If you want to coarsen the mesh then you can do it in workbench meshing by increasing the sizes.
You can check this video.
If you want to do it in Fluent then you can convert mesh to poly with Setting up domain - Mesh - Make polyhedra
November 19, 2018 at 11:07 am
seeta gunti
Ansys EmployeeWe can also increase the element size by adapting the grid. In R19.2, Fluent has dynamic mesh adaption. With this we can either increase or decrease the mesh.
SEeta
July 22, 2019 at 10:20 am
PeterBeshay
SubscriberCould you please provide the tutorial for this video?
July 24, 2019 at 3:44 pm
Ansys EmployeeThat looks like the Dam Break tutorial:
Assuming you're using 2019 you'll need to figure out the Adaption tools as the panels are slightly different.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2146
1357
1144
462
