Decreasing heat flux value
    • azizi0407
      Hi,nnI?m modeling a forced convection around cylinder in porous media. As I increased the Reynolds number, the heat flux decreased. Shouldn?t it increase? What is the problem here? How to Ansys Fluent compute heat flux?.Thanks for any advice in advance.n
      Yes, and no. Has the flow separated, and what is the boundary condition on the cylinder?n
    • azizi0407
      Hi Robnnthe conditions no slip condition and heated. The flow does not separate as it?s model using Hele-Shaw cell. So it will be like a Potential flow around a cylinder.nnthanksn
      Can you post some images of velocity vectors & temperature contours?nSpecifically what thermal boundary did you use on the wall?
    • azizi0407
      This is the temperature contour image at Re=2100 and Pr=7. It’s look weird as the flow didn’t past the heated cylinder.n
Viewing 4 reply threads
