March 12, 2021 at 12:21 pm
Rajan_Mistry
SubscriberI am using a waveport to excite my microwave structure in HFSS (driven modal solver, fast frequency sweep), but what is the default excitation waveform used by HFSS when solving? I was expecting see a voltage vs time sinusoidal plot but cannot find this information anywhere? Is there a way to export the default excitation waveform as a csv file?n -
March 12, 2021 at 4:28 pm
Praneeth
Ansys EmployeenIf you are using Driven modal then the excitation will be composite power but not voltages. If you would like run simulations in terms of voltages then try using driven terminal solution. Please refer the HFSS Help document for more information. nAll the very best.nBest Regards,n -
March 12, 2021 at 4:42 pm
Rajan_Mistry
SubscriberIs there a way to view the frequency components of this composite power excitation signal ? -
March 17, 2021 at 1:19 pm
Praneeth
Ansys EmployeeHi,nThe default excitation is 1W of power whose frequency is equal to the solution frequency set up by the user. For more information you can go though the HFSS Help document under section Assign Wave Ports for Modal Solutions.nAll the very best.nBest Regards,n
Viewing 3 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
